The Model B and Model A crankshafts and main caps are different. What is the difference? Can either of these Model A parts be used on a Model B and vice-versa?
Those who do not move do not die, but are they not already dead? |
Answer to part of my question: both rod and main bearings are larger. But can any of the parts be interchanged between the A and B.
Simple answer is no.
The larger mains can be turned down to the smaller A size and use
B rods. I think you have to dimple the A pan for the bigger rod to not hit. |
Bob, Thanks for the info.
You can turn down the B crank mains to Model A and offset grind the rod journals .125 and have a stroke of 4 3/8. Bore it .125 over and you have 230 cu. in. just say'n
Better to grind mains to 1.850 and use inserts
J
As Carroll Smith wrote; All Failures are Human in Origin. |
Model B cranks have an advantage in that about half the cranks extant are "counterweighted" with forged-on counterweights. That is not to say that a non-counterweight B or even an A crank can't have "weights" applied. Some here have gotten VERY good at applying and weld-staking applied weights.
Of course the usual thought is to reduce your rotating mass by cutting down the flywheel afterwards - something which the Model A can benefit from since the stock flywheel is a little "overweighted" anyway. Reducing the rotating mass MAY make the car drive more like a "modern car" (if that is your objective) with a slight tendency to increase clashing of transmission gears. The whole Ford thought between flywheel weight and drivability was one of how to best balance the two downsides in shifting: spin down and clash. Joe K
Shudda kept the horse. Last edited by Joe K; 12-09-2025 at 06:49 AM. |
The main bearings on a B crankshaft are 2" in diameter. The clearance between the main bearing bolts in an A engine is 2". Bearing inserts generally come in increments of 0.010" so even at the first undersize inserts, there will be 0.005" clearance between the journal and the bolts. I have wondered about reducing the main bearing journals to the next insert size and boring the block to take them and use B rods also altered to take inserts. The main bearing inserts would be the same ones that Terry used in his new motor. (but undersize)
I have a B engine running on inserts The inserts I described above are used in the main bearings and the rod bearings are from a (I think) Toyota fork lift engine. I have the numbers if anyone is interested. Both the mains and rod bearings are 0.020" undersized. As has been mentioned, with all of that extra weight in the crankshaft, lightening the flywheel is recommended.My only reservation is the As gravity oil feed to the main bearings. If the motor goes a lot better that an A engine, it will be driven faster and harder so pressure feeding the mains becomes more important. At the end of all of this, I decided to not try to reinvent this particular wheel so I bought one of Terry's engines and left all the head scratching to him.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
