Old 10-29-2025, 11:07 PM   #1
Gary WA
Gary WA's Avatar
Default Today's Main Model A Wiring Harness
What does the Fordbarn family of Model A Fords think about the New Main Wiring Harness that are on the Market today? Just Curious!!
www.whidbeymodelaclub.com
Old 10-30-2025, 06:33 AM   #2
Joe K
Joe K's Avatar
Default Re: Today's Main Model A Wiring Harness
I have heard that the "dimples" in the circular contact plate are not formed "deep" enough to capture the switch feelers, thus you turn the wheel and it seems to turn your headlights on and off.
Joe K
Shudda kept the horse.
Old 10-30-2025, 07:12 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Specifically which one (-which manufacturer) are you referring to?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-30-2025, 11:54 AM   #4
Gary WA
Gary WA's Avatar
Makes no difference.
Old 10-30-2025, 12:52 PM   #5
BRENT in 10-uh-C
Ok, ...maybe not -but some are definitely better quality than others. Since I don't use all of them, not sure I could say which is good and which aren't.
BRENT in 10-uh-C
Old 10-30-2025, 01:10 PM   #6
32Ford13
The one I got from Bratton's (Bauer made) was stellar quality and a dream to work with.
32Ford13 is offline   Reply With Quote
Old 10-30-2025, 01:33 PM   #7
Klattu1929
I purchased a main 2-bulb harness from Snyders last year, very hard to rotate switch on steering wheel, took apart and added silicone dielectric grease to the dimples. Works great now, have headlights, parking lights, and taillights/brake lights. switch on steering column doesn't move with steering wheel. Two thumbs up.
Klattu1929 is offline   Reply With Quote
Old 10-30-2025, 02:14 PM   #8
CarlG
CarlG's Avatar
The harnesses I have purchased from Sacramento Vintage Ford are awesome. Never had a problem with them, some have been in use over 15 years now.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-30-2025, 02:41 PM   #9
ModelA29
ModelA29's Avatar
That's where I bought mine. I've had it over a year and will finally install it in the next couple weeks. I bought it because it had the correct headlight contacts.
ModelA29 is offline   Reply With Quote
Old 10-30-2025, 07:42 PM   #10
Y-Blockhead
Y-Blockhead's Avatar
If I remember correctly, on some of the new wiring harnesses the bakelite is too thick and causes difficulty in turning the switch.
On Bratton's catalog there used to be a procedure to fix this problem. But it is no longer on their site.
Old 10-31-2025, 04:27 AM   #11
KMBeers
KMBeers's Avatar
Mine was tight from Snyder’s as well, Jus like post 7 I used a little grease but also used a 5/16 ballmill by hand and dressed the dimples a little deeper. Been 3 years and 2k miles and works perfectly
KMBeers is offline   Reply With Quote
Old 10-31-2025, 10:52 AM   #12
Bob Bidonde
Bob Bidonde's Avatar
These slides may help fix the light switch issue.
Bob Bidonde
Old 10-31-2025, 11:11 AM   #13
rotorwrench
rotorwrench's Avatar
Bauer Electronics may be a main source for most Model A parts suppliers. Rhode Island Wire coats their insulation which may help it last longer. The woven cloth wire covering doesn't seem to stay color fast very long if it's exposed to too much humidity and especially sun light. The old original stuff used a resin under the outer covering that didn't last as well as the modern insulation so any of the newer stuff is more durable in that respect. The only problems I've noticed is that the modern stuff seems to have a larger cross sectional diameter than the original so getting the modern stuff to fit into multi wire conduits and the like can be a challenge on cars of the late 40s & early 50s. This isn't an issue on the older Fords like the model A
