I have a 35 pickup with a later engine. The serial number is 18 1346997. What is the year of this engine. The water pumps are on the block and don't match any pumps I see for sale. They have an extra hole opposite the mount flange.
That extra hole (2 holes each side) is in the block not the pump. Those holes were used for a front engine mount in trucks. Looks the same as the 39 and 41 pumps I have in my parts pile.
I am building a 1939 1 ton express |
#3 | |
Ford flatheads do not have serial numbers. That number might be your frame number and also the number on your transmission if it has not been replaced. If your engine has 21 cylinder studs the engine is probably a 1937 or possibly 1938. If it has 24 head studs it could be up through 1948 I believe. If I am wrong I will be corrected shortly.
What numbers are on the heads?
DSCN1219.jpg |
#7 | |
#8 | |
Yes the transmission case is 1935 but the engine is not due to the water pumps. The heads can be moved from one year to another within limits so the numbers on the heads shouulld not be used to date the engine. You have to look at the engine block features. Suggest you look on the vanpelt web site where they describe the features.
A picture of one of the heads would be helpful as cas3 mentioned.
That would identify the "heads". Is the intake mounted surface flat, or have the appearance of having a raised deck the shape of the gasket? Give us more clues... crank mount fan? Distributor type?
Casting number on bell housing above the flywheel? Last edited by big deuce; 10-29-2025 at 10:04 AM. |
#12 | |
#13 |
I am going to say this very very slowly so you will understand.
Ford Motor Company Never put a serial number on any 1932 - 1953 Flathead V8 or 4 Cylinder engines. Henry did this so the cars would have interchangeable engines. The number was on the bellhousing and frame on the V8 and flywheel housing and frame on the 4 cylinder. Some states required an engine number so the dealer selling the car would often stamp the number on the block just outside the intake manifold. They were not done with factory font Stamps nor did they have a star on them such as the Model A did.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go?
