Old 10-25-2025, 02:58 PM   #1
allenmichael
Default connectors on throttle rod and choke levers
how does one re use those under dash metal (lead?)connectors that connect the throttle rod in dash to rod from carb?
allenmichael is offline   Reply With Quote
Old 10-25-2025, 02:58 PM   #2
allenmichael
Default Re: connectors on throttle rod and choke levers
it's on a 1936 Fordor
Old 10-25-2025, 03:47 PM   #3
The Art Doctor
The Art Doctor's Avatar
My '34 has little metal sleeves about an inch long with two threaded holes and very small set screws.
The Art Doctor is online now   Reply With Quote
Old 10-25-2025, 04:24 PM   #4
KiWinUS
KiWinUS's Avatar
Crimp with really good wire terminal crimpers for uninsulated wiring terminals.
KiWinUS is online now   Reply With Quote
Old 10-25-2025, 05:42 PM   #5
Model51
Model51's Avatar
You can also use a good quality epoxy adhesive to make the joint. The original Ford specification was the joint should be able to withstand 100 pounds of pull force.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 10-25-2025, 08:16 PM   #6
koates
The original sleeves were crimped to the rods with a crimping tool like an electrical terminal crimper. Some Reproduction sleeves have threaded grub screws. Try THIRD GENERATION AUTO for the reproduction sleeves. Regards, Kevin.
koates is offline   Reply With Quote
Old 10-25-2025, 08:24 PM   #7
Gary Tosel
Gary Tosel's Avatar
My experience with the connectors was that they were so hard they would not crimp properly, so I located then with the choke and throttle names aligned with the connectors located, then removed them and used a wire feed welder to spot weld in place. Just my solution.
Gary Tosel is offline   Reply With Quote
Old 10-26-2025, 07:35 AM   #8
allenmichael
thanks all!!
Old 10-27-2025, 06:27 PM   #9
Kube
Super Moderator
Kube's Avatar
I use my wire fencing ferrule crimping tool. Similar to an electrical wire connector tool but MUCH more heavy duty.
Old 10-28-2025, 05:44 AM   #10
glennpm
glennpm's Avatar
Yes, it's a Nicopress. I have and used one to shorten the '40 emergency brake cable.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 10-28-2025, 05:49 AM   #11
32Bee
I very easily threaded the little reproduction seeves and the ends of the reproduction
choke and throttle rods. Works really well.
32Bee is offline   Reply With Quote
Old 10-28-2025, 07:41 AM   #12
Kube
Super Moderator
Kube's Avatar
Thanks Glenn. That's the tool indeed!
Old 10-28-2025, 09:55 AM   #13
Seth Swoboda
Seth Swoboda's Avatar
Kube, I like the fact that I'm not the only one here who builds and repairs fence also.
Old 10-28-2025, 10:28 AM   #14
rockfla
rockfla's Avatar
I made my own, used a couple of like 1/4 diameter (or 5/16th's) 3" long Stainless Steel bolts. Cut the heads and threads off of them, drilled two holes in each end and tapped them for 6/32 set screws. Then mic'd the choke and throttle rod shafts and drilled the hole down the center on my lathe!!!
Old 10-28-2025, 10:55 AM   #15
Kube
Super Moderator
Kube's Avatar
Never ending...
Twelve horses, eight pastures... LOTS of posts and wire.
I'm getting old methinks.
Old 10-28-2025, 11:09 AM   #16
34fordy
34fordy's Avatar
You thinx right Mike and aren't we lucky to still be doing it!!!!!!!
34fordy is offline   Reply With Quote
Old 10-28-2025, 11:12 AM   #17
34fordy
34fordy's Avatar
Can you show us the holster that you carry it in, or the scabbard next to the saddle on your horse?
Old 10-28-2025, 11:25 AM   #18
Kube
Super Moderator
Kube's Avatar
Yes indeed. I am not complaining one bit. Yes, things seem heavier than they once did (increased gravitation pull methinks) and yes, there are less than twenty-four hours in a day (well, it seems so) but man oh man, life is good
Old 10-31-2025, 12:30 PM   #19
rsauto
Will JB weld hold them? Has anyone had luck with that?
rsauto is offline   Reply With Quote
Old 10-31-2025, 03:25 PM   #20
glennpm
glennpm's Avatar
I don't think that there would be enough epoxy between the rods and the connector even with a filet of JB Weld on the ends. You may be better off soldering it, buff, clean, flux and solder. Crimping is the best way though.
Rumble Seat’s Notes
