07-20-2011, 07:20 AM | #21 |
Re: Modern points vs original model a points
Besides converting many Model A distributors to use Ford V8 points/condensers, I have fabricated parts to allow both Lucas and Marelli distributors to use "modern" points/condenser combinations. I have not noticed much improvement in venicle performance from any of these conversions. However, the peace of mind that has come with knowing that I can buy replacement parts on most any street corner has improved my attitude toward driving the cars that are equiped with these modifications.
07-20-2011, 07:24 AM | #22 | |
Which brings me to the facts. A properly rebuilt distributor with quality parts should out last the grand children. NOTICE I did not say what type of points or condenser. Same amount of work to make it original or modern. Use whatever logic makes you happy to justify your choice. Please just do it right and have just one less thing to worry about. The A done right is a fun, minimal maintenance driving machine. |
07-20-2011, 07:38 AM | #23 |
07-20-2011, 07:43 AM | #24 |
I always used to keep a spare set of points & condenser in the glove-box... I often find extra sets there when I get a "new" car...
In this day and age, I wouldn't necessarily count on being able to find ANY points at just any corner store or strip-mall... I have noticed with contact sets of recent manufacture (installed in "modern" vehicles, such as a 1960 Chrysler and a 1972 Chevy pick-up (six cylinder), that the rubbing-blocks seem to wear-down faster, even with a dab of cam-lube or vaseline on them... Back when I was a kid, one of my Uncles use to swear by Sorensen points - one of the contacts had two deep grooves across the face, forming a cross... the claim was this helped keep the contacts cooler... I don't think I've seen a set of Sorensen ignition parts in at least 40 years... |
07-20-2011, 07:53 AM | #25 |
Consider this- you're on tour with a bunch of Model As. Your modern points go south and you don't have a spare. The guy's you're with have twenty spare sets of original points among them, but you're on the flatbed because you went modern.
07-20-2011, 07:56 AM | #26 |
07-20-2011, 08:00 AM | #27 |
I have a spare set of points, condenser and coil in our A under the seat. I would be more worried about the coil failing then modern or original points. Usually if not always points are repairable to get you home. A cooked coil is not and no one sells a 6V coil locally that I know of.
