Is there any advantage or disadvantage as to whether I can use 8BA head gaskets?
I have always used the 59A gaskets, but I now have several sets of 8BA's hanging on the wall. It means I have to buy a complete 8BA gasket set AND a pair of 59A head gaskets... Thanks. |
When I installed early style heads on my 8BA block I had to use early style head gaskets as 8BA gaskets won't work.
#3 | |
My French motor has 8BA type head faces. I use 59A style Edelbrock heads.
I use 2 right side 8BA gaskets. One has to go on upside down. I trim off the extra sticky out bit from the gaskets. I show it in this video. https://youtu.be/YPozuUEAmJM Mart |
19Fordy, I still LOVE that engine, could stare at it all day .......
You need to use 59A gaskets whenever mixing and matching blocks and heads between the two variants.
And the extra coolant hole needs to be plugged in the 8BA component.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
Thanks everyone!
I've ordered a set of 59A's Thanks Mart, I watched the video, a couple of good tips. |
Thanks, gentlemen, for the kind "engine words".
