Old 09-09-2025, 12:29 PM   #1
marko39
Default 39 deluxe sealed beams
Can sealed beams be installed in 39 deluxe buckets? Car is still 6 volt and I want to keep the 39 lenses and trim ring. I have new Drake buckets .
marko39 is offline   Reply With Quote
Old 09-09-2025, 12:43 PM   #2
rockfla
rockfla's Avatar
Default Re: 39 deluxe sealed beams
Isn't part of converting to sealed beams ditching the original trim rings and lenses, using a "specially made" trim ring to fit and hold the sealed beam light AND the reason of they look SO damn ugly!!!!!! Hideous actually!!!
Old 09-09-2025, 12:59 PM   #3
mcgarrett
I believe that is correct. Due to the design of the stock headlight, you would need to use those horrible looking pot metal adapters. The original headlights are aesthetically much prettier, IMO.
Old 09-09-2025, 01:00 PM   #4
Newc
Newc's Avatar
Or switch to true '40s .Sell me your stock '39 dlx parts. Newc
Old 09-09-2025, 01:07 PM   #5
mcgarrett
I think you would need '40 headlight buckets, sealed beam retainer rings, and outer chrome trim rings. Not sure if it's a direct bolt-up affair, but it has been done.
Old 09-09-2025, 01:37 PM   #6
rockfla
rockfla's Avatar
IF brighter headlights and lights in general are your goal, why not switch to LED's.....Steve Blanchard here on the Barn "ndchf" (i think that's his moniker) generator extraordinaire has done it on his 35 and has rave reviews about it!!!
Old 09-09-2025, 03:15 PM   #7
marko39
Yes, I agree and when I got the car it had 40 lights which I prefer the 39. Conversions I’ve seen are for 12 volt and I have the 40 buckets which I may try to strip and install in the 39. Hoping to hear from someone who has done this.
Old 09-09-2025, 07:48 PM   #8
Kube
Super Moderator
Kube's Avatar
Yep. Switch to '40 buckets and all the 40 stuff fits right in. No fuss, no muss.
Old 09-09-2025, 08:05 PM   #9
Newc
Newc's Avatar
Tried to find Drakes halogen 39 set, but no luck. Long gone with a lot repro of parts. Newc
Old 09-10-2025, 08:10 AM   #10
marko39
I have the 40 buckets but the 39 lenses don’t fit because they fit the contour of the fender and the 40 lights sit proud of the fender. If I can remove the 40 guts and install in the 39 buckets I think it will work as the 39s are deeper than the 40. Got some cleaning up to do to see how they’re held together. I am open to any other suggestions and wouldn’t mind going stock if I could find all the parts.
Old 09-11-2025, 11:21 AM   #11
TJ
TJ's Avatar
If your light has to pass through two lenses (seal beam and 39 lens) your light will be scattered all over the place. Not the best idea.
Old 09-11-2025, 12:50 PM   #12
marko39
I was just thinking the same thing. Got the 40 buckets stripped but fitting them to the 39s isn’t going too well. Very tight due to the buckets different shape. If I can make it work the bulb would be close to the lense. I’ll probably search for what I need to make it stock.
Old 09-14-2025, 07:46 PM   #13
38 coupe
38 coupe's Avatar
I have used halogen bulbs that fit the original reflector with no modification. Little British Car Co has bulbs with the filaments in the correct location. They offer the following bulbs for 37-39 Ford cars:
170-756H - 6V, 35/35W, use with generator
170-957H - 6V, 50/35W, use with generator
170-857HA - 6V, 60/55W, use with alternator
170-760H - 12V, 35/35W
170-857HA - 12V, 60/55W
170-759H - 12V, 65/55W
I used the 170-957H bulbs in a stock 37 sedan with new reproduction reflectors and lenses with excellent results. I have now purchased duplicate stock to do the same upgrade on my 38 cars.
Currently C&G lists the new reflectors, I found them to be a big improvement over my tarnished originals. Other vendors probably sell them too.
Old 09-15-2025, 06:51 AM   #14
marko39
thanks for the info, sounds good.
Old 09-15-2025, 05:22 PM   #15
TJ
TJ's Avatar
If you do the halogens be sure to use relays so the switch is not overloaded. Found this out the hard way.
Old 09-16-2025, 09:03 AM   #16
marko39
Can you tell me what relays you used and how to wire them? I never was very good with electrical. Thanks
Old 09-16-2025, 11:21 AM   #17
TJ
TJ's Avatar
Marko I can't recall as it was a long time ago. I recall I got them from Napa Auto Parts. I think they had instructions with them. You should be able to also find instructions on the internet.
Old 09-16-2025, 02:24 PM   #18
corvette8n
corvette8n's Avatar
Here’s some relays, I used one for my ahooga horn I added to my ‘41.
Old 09-16-2025, 02:50 PM   #19
petehoovie
petehoovie's Avatar
Old 09-18-2025, 06:55 AM   #20
marko39
Still exploring my options as I don’t see anyone who has original headlamp sockets.
