Old 09-05-2025, 05:47 AM   #41
38 coupe
38 coupe's Avatar
Default Re: Serpentine System for Flatheads
I don't think all that is needed. My friend has a 41 Mercury with air conditioning and an alternator running one wide V belt. It does the job well without added complication of idlers or extra belts.
Old 09-05-2025, 08:13 AM   #42
glennpm
glennpm's Avatar
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
glennpm is online now   Reply With Quote
Old 09-05-2025, 12:02 PM   #43
slowforty
At one time I painted the water pump pulleys pink with red tips. Caused quite a few comments. I was single at the time.
slowforty is offline   Reply With Quote
Old 09-06-2025, 10:07 AM   #44
Bored&Stroked
Bored&Stroked's Avatar
Maybe that was the key to you becoming hitched?
Bored&Stroked is online now   Reply With Quote
Old 09-11-2025, 02:20 AM   #45
vincent
I had a serpentine belt system on my flathead. It drove the blower as well but always started to slip at about 3500 revs. Putting more and more tension on the belt only resulted in a sqeaking bearing of the LH waterpump.When the clutch finally started to slip as well, it was time for a re-design. I made pulleys for a 2" toothed belt and fitted a 11" clutch - no problems now.
vincent is offline   Reply With Quote
Old 09-11-2025, 06:30 AM   #46
glennpm
glennpm's Avatar
Rumble Seat’s Notes
