Old 08-19-2025, 06:38 PM   #6
Kube
Super Moderator
Kube's Avatar
Default Re: King Pins
Originally Posted by cas3 View Post
Bleeding the brakes would be the easiest part of the job. I've never attempted to do pins and bushings on the car, always axle out and use a big press to get the pins out. Normally, quite a fight. You can still leave the backing plates dangle with hose connected as above, but I'd be doing wheel cylinders and bearings while you're already there.
I have heard many such horror stories.
I believe I have been lucky, heck, I KNOW I have been lucky. I have never spent more than a half hour on any old pin removal. Even prior to getting the bolt on KRW press, none took more than a number of whacks with a 4# hammer to move them out.
To me, it was always a bigger PITA to remove the backing plate to spindle nuts / cotter pins.
