Old 08-18-2025, 07:20 PM   #1
Shoebox
Shoebox's Avatar
Default 90 wt HYPOID lube vs 80-90 GEAR oil
Maybe terminology has just changed, but I used the proper gear oil to fill my 3 speed w/od trans and now am ready to top off the diff with the specified 90 wt HYPOID lube. I have read the definition of Hypoid, it is for ring & pinion type gear sets. I am having trouble finding this, I see some marine applications, long story well long,... what are folks using for diff lubrication? Thanks!
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 08-18-2025, 07:38 PM   #2
paul2748
paul2748's Avatar
Default Re: 90 wt HYPOID lube vs 80-90 GEAR oil
I use regular 80-90 gear oil
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-18-2025, 09:13 PM   #3
John R
The conventional wisdom is to use GL-4 gear oil in the trans and GL-5 gear oil in a hypoid differential like a shoebox Ford. (The banjo-type earlier differentials (spiral bevel, not hypoid) would use the GL-4.) Have not seen the word "hypoid" used much on labels, just the generic "gear oil" or similar designation.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 08-19-2025, 10:31 AM   #4
Fritz
Fritz's Avatar
You need GL-4. GL-5 will attack the yellow metals in your trans. You can run GL-5 in the diff, but I keep it simple and put 140 GL-4 in the trans and diff. You can find the MasterPro brand cheap at Oreillys. I’ve read Van Pelt recommends 140 for the trans. I like the way mine shifts with it over 90 oil.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 08-19-2025, 10:30 PM   #5
farmertom
farmertom's Avatar
exactly what i use in my '37 trans and diff. Tom.
farmertom is offline   Reply With Quote
Old 08-20-2025, 09:19 AM   #6
Shoebox
Shoebox's Avatar
All good comments guys, thanks much. FWIW I found the Sta-lube line by CRC has various weights recommended for Hypoid gears as well as other applications.
32 Ford roadster
39 Mercury Towncar
Old 08-21-2025, 03:28 PM   #7
richard crow
when the pinon gear is below the ring gear center it is a hypoid rear
richard crow is offline   Reply With Quote
Old 08-23-2025, 07:26 AM   #8
corvette8n
corvette8n's Avatar
Millers oil options, I think you can get it on Amazon.
Old 08-23-2025, 09:39 AM   #9
leon bee
Sta-Lube 140. Was easy to find, haven't looked for a while.
leon bee is offline   Reply With Quote
Old 08-23-2025, 09:48 AM   #10
19Fordy
19Fordy's Avatar
O'Reillys sells GL-140.
https://www.oreillyauto.com/search?q...ckajYwJGwwJGgw
Old 08-28-2025, 06:33 PM   #11
Shoebox
Shoebox's Avatar
If 140 works for you that's all that matters. That said, I was talking to Mac Van Pelt today regarding the 3 spd/OD trans he built for my '51 Tudor, and said to use GL-4 85-90 gear oil not 140, which is more for truck transmissions. I have a jug of Sta-Lube GL-4 85/90 coming.
32 Ford roadster
39 Mercury Towncar
