I have fixed Stromburg inlets by making my own inserts. Your heads could use the same idea. I selected a bolt and drilled and taped it to the size needed. I partially tapped the part so the insert could not screw thru. Thread locker so it would not screw out You would have a permanent fix and no welding.
