Hey guys
So im back on working on my daughter's 36 sedan school starts soon and she wants to drive it . So is there any suspension kits for this car so she doesn't sway So much around corners.. All stock suspension with the dog bone shackles things for a little bit of lowering along with the front spring Thanks guys again |
#2 | |
Im looking to see if anyone has done one of these shock kits I see online if so thoughts
This is a simple build nothing crazy |
If you used longer shackles you have answered your own question. That is your sway problem. You should use a dropped axle with stock shackles and a tube shock kit on front and rear. You can lower the rear by having a spring shop lower the arch of the spring. If you still have mechanical brakes the dropped axle will not work with them.
#5 | |
Yeah using mechanical brakes Will look up those tube shock kits also Thank u |
Easy to lower the back of that car too....you can fit lowering blocks between the radius rods and rear axle housings. I made my own, but there is someone in the states that sells them.
https://carrillocustoms.com/products...ering-brackets
https://www.fordbarn.com/forum/showthread.php?t=58142
Thanks
