Old 07-25-2025, 05:07 PM   #1
Larry29
Default 30 tudor quater windows
hi installing new felts for my quarter glass and door glass, does anyone know where I can get outer glass sweeps for a tudor sedan? I hate having the outer part of the windows open to weather conditions and if I install a air condition unit in the car it would be nice to seal that off.
Larry29 is offline   Reply With Quote
Old 07-25-2025, 05:46 PM   #2
History
History's Avatar
Default Re: 30 tudor quater windows
Apparently they did not come from the factory with anything on outside of the windows. I just did the anti rattles on mine and found this out from the members here. I know it doesn’t make sense today but they were learning what needed to be at the time.
History is offline   Reply With Quote
Old 07-26-2025, 08:14 AM   #3
jak
That is correct, from the factory there was nothing to stop the water from running down the glass into the quarter panel. There should be some drain holes at the bottom just make sure you keep them open.
jak is offline   Reply With Quote
