Anyone have a diagram, or good photos are positioned for a 1930 passenger side coupe door lock?
Brian SATX |
Should be where the springs are positioned.
Brian SATX |
there is a trick on installing those colored springs. Some expert here hopefully should help you. it involves winding the spring and holding the wound-up unit with a clamp
Clem |
Brian
Do you mean door lock, which is in the handle or door latch, which holds the door closed?
Bill Cilker, Jr Unrestored 190A Victoria 45B, & 160B Victoria Association President |
door latch inside the door.
Brian SATX |
It's not the destination ,it's the journey . |
