Old 07-15-2025, 11:03 PM   #1
jeffgies
Default Model A tudor window trim removal
How does one remove the upper interior window trim/molding from the rear (side) windows of a 30-31 tudor? I'm not seeing any clips or screws holding it in place.
Thanks
jeffgies is offline   Reply With Quote
Old 07-16-2025, 06:58 AM   #2
Big hammer
Default Re: Model A tudor window trim removal
The upper rear corner of the quarter window trim ? Just pull it forward.
get a bigger hammer tap done
Old 07-16-2025, 03:00 PM   #3
AYooperA
If memory serves there’s a tab extending past that corner with a c’sunk wood screw securing it. The upper upholstery panel hides this fastener.
AYooperA is offline   Reply With Quote
Old 07-17-2025, 10:05 PM   #4
jeffgies
You are absolutely correct. I found 2 tabs (welded) at the front end of the frame and a plate that kind of clamps it into place at the rear. Mine is a Canadian car btw. Once removed, pulling downward freed the trim from the car.
Thanks for the input.
Are these pieces as hard to find as people say? I don't have the driver's side trim.
Old 07-23-2025, 08:12 PM   #5
Anisalistreri
Yes jeffgies, compatible pieces are quite hard to find on the market these days.
Anisalistreri is offline   Reply With Quote
