Old 07-16-2025, 03:00 PM   #1
AYooperA
Default Re: Model A tudor window trim removal
If memory serves there’s a tab extending past that corner with a c’sunk wood screw securing it. The upper upholstery panel hides this fastener.
AYooperA is offline   Reply With Quote
Old 07-17-2025, 10:05 PM   #2
jeffgies
You are absolutely correct. I found 2 tabs (welded) at the front end of the frame and a plate that kind of clamps it into place at the rear. Mine is a Canadian car btw. Once removed, pulling downward freed the trim from the car.
Thanks for the input.
Are these pieces as hard to find as people say? I don't have the driver's side trim.
jeffgies is offline   Reply With Quote
