Old 07-03-2025, 11:09 AM   #1
old ugly
old ugly's Avatar
Default Re: install a carter electric fuel pump question??
Here is the solution.
There is so little psi at the model a carb which was originally being supplied fuel via gravity that this fuel pump and regulator set up on a remote tank can not be set low enough. The pressure always overpowered the float needle.
The solution is to run a return line back to the gas tank with a restricted fitting in it.
Now The fuel is constantly bleeding back to the tank reducing the pressure at the carb to minimal.
I tried to get a photo but not having any luck loading it.
Thanks
OU
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
