Old 06-30-2025, 07:24 AM   #1
Panheadguy
Default Centrifugal advance distributor
Wanting to ad centrifugal advance so wife can drive and not worry about manually adjusting. I have a Honda Civic points distributor I modified to fit.
Want to keep reverse polarity as original. Can I wire the armored cable to the terminal on the distributor and leave everything as is?
Thank You
Panheadguy is offline   Reply With Quote
Old 06-30-2025, 08:18 AM   #2
nkaminar
nkaminar's Avatar
Default Re: Centrifugal advance distributor
If mechanical points and not an electronic condensor, then yes. If electronic ignition then no.
It is not hard to change polarity. Since the battery is hidden under the floor boards, you will be the only one to know.
Old 06-30-2025, 08:39 AM   #3
Ruth
I would guess if it is electronic it would also be 12 volt?
Ruth
Old 06-30-2025, 08:49 AM   #4
nkaminar
nkaminar's Avatar
Another thing to be concerned about is the advance curve. That will depend on whether you have a stock or higher compression head and other things. You don't want to have the timing too advanced or the engine will eat connecting rod bearings.
Old 06-30-2025, 08:52 AM   #5
Panheadguy
It is a points dist. Are you suggesting I would need to reverse polarity? I was hoping to leave it pos ground to not affect charging.
Old 06-30-2025, 08:54 AM   #6
Panheadguy
It's all stock. I will see what advance the distributor has and limit it. I think I read 29' is about the max?
Old 06-30-2025, 09:23 AM   #7
katy
katy's Avatar
What year(s) would that be?
Old 06-30-2025, 09:49 AM   #8
cadillac512
cadillac512's Avatar
You can use it pos ground no problem. The points dist doesn't care.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is online now   Reply With Quote
Old 06-30-2025, 10:15 AM   #9
AzBob
In a nutshell, the Honda Civic points distributor’s advance curve full advance will come in at a much higher rpm. I don’t have exact numbers. For example max advance on the Honda engine will be in the neighborhood of ~ 4500 rpm. Whereas you want the Model A engine to be at full advance ~2000 rpm.
To accomplish this will need manipulation of the bob weight springs or the bob weights themselves. Also need a means to verify. Can be done in the car with a timing light setup. Ideal setup would be with the distributor mounted in a distributor machine.
AzBob is offline   Reply With Quote
Old 06-30-2025, 10:16 AM   #10
Richard Knight
Is it made to turn CCW. If not the advance won't work right. You will need to check total advance around 2k engine rpm.
Richard Knight is offline   Reply With Quote
Old 06-30-2025, 10:26 AM   #11
AzBob
Corley has done the Honda Civic distributor conversion a while ago and is considered the guru for this conversion. See link here:
https://www.fordbarn.com/forum/showthread.php?t=244492
Old 06-30-2025, 10:55 AM   #12
Brendan
Brendan's Avatar
I have a FS disributer in my A , its 12 volts negitve ground , ita also ,centrifugal advance , and electronic, it works good, and has given me no trouble
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 06-30-2025, 11:27 AM   #13
nkaminar
nkaminar's Avatar
Pan Head Guy, I was just suggesting that changing the polarity would be easy, IF NEEDED. Since it is mechanical points, positive ground is just fine. The only other polarity consideration is if the condensor is the electronic type, made using semiconductors. But I have never seen that on a car and it would probably not work because the ignition system rings, with positive and negative voltage on the condensor.
Old 06-30-2025, 12:10 PM   #14
Panheadguy
NKAMINAR, Thanks for chiming in with short concise info. Yup std. old shiny metal condenser, was more concerned with how the charging system reacts to reverse polarity.
Getting this heap read for the 4th of July parade. I did reach out to Corley but have not heard back from him.
Old 06-30-2025, 12:11 PM   #15
Panheadguy
He favors the electronic Honda dist. which is happy at 12v.
Old 06-30-2025, 12:12 PM   #16
Panheadguy
It does turn CCW
Old 06-30-2025, 12:17 PM   #17
Panheadguy
I think '78....but some of the ones I saw in that era were different where they mounted, I picked one with points that looked right. Inthe past I have used CJ2A Willys Jeep distributors but on 12V and they are getting $
Old 06-30-2025, 03:14 PM   #18
Y-Blockhead
Y-Blockhead's Avatar
It may be easier to get a Nu-Rex Auto Advancer. The advance is already setup for the Model A. Then you can use your original distributor and everything will look stock.
https://www.snydersantiqueauto.com/8...htm?pid=976340
Old 06-30-2025, 03:38 PM   #19
Cape Codder
Cape Codder's Avatar
I sure would like to hear from anyone that has the Nu-Rex setup in their engine and how does it perform? Lastly, how many miles have you driven with it installed? Is it worth buying?
I don't care if the "A" Starts BUT sure WANT IT TO STOP!
Cape Codder is offline   Reply With Quote
Old 07-01-2025, 09:47 AM   #20
Y-Blockhead
I do have one in my Town Sedan. Edit: I(t was) installed before I bought the car ~10 years ago. I have never had a issue with it. I set my timing for full advance at 28° BTDC. I have a high compression head.
For more info, check out this article on Vince's Ford Garage.
https://www.fordgarage.com/pages/nurexadvance.htm
https://www.fordgarage.com/pages/phillipsspark.htm
