Old 06-30-2025, 06:55 AM   #1
Bruce of MN
Bruce of MN's Avatar
Default Right Headlight Mounting
My coupe has a spacer for the mounting stud that is about the thickness of the horn bracket on the other side andhas some shallow serrations. I don't see it in the Parts Price List. Is it stock? It seems like a good idea.
Old 06-30-2025, 10:09 AM   #2
Steve Schmauch
Default Re: Right Headlight Mounting
Originals do not have any spacer as you have described. It is not necessary.
Steve Schmauch is offline   Reply With Quote
Old 06-30-2025, 10:28 AM   #3
Ruth
What would be the purpose of this item.
Ruth
Old 06-30-2025, 11:11 AM   #4
Bruce of MN
It makes both studs project the same under the nut. What difference that makes? Not much, unless it is stock. That is not looking too likely, though.
