If you happen to have access to the inspection cover at the front of the trans, you could look in there. A flat flywheel is gonna be a 10", and the thick blob flywheel is gonna be a 9"
JMO but if you need a new clutch stay away from Ft. Wayne Clutch. They used to be a go to source. Today, not so much.
Not just your opinion. Mine as well as many others too.
Well, yeah, maybe. Every clutch replacement I have done (too many to recall) I have cut that bell off of the flywheel.
