#21 |
On most of our old cars, the problem starts in the TANK . . . have it cleaned . . . thoroughly. If there is corrosion/rust in it . . . then the problem can be such that the tank needs to be replaced.
I brought my 32 tank to a big truck service place that had a "stream wand" that they used to clean the tank out. I've not had a problem with it and it was super gunky (had sat for 50 years - originally with fuel in it). |
#22 |
#23 |
Curious is any of that debris was ferrous and could be picked up with a magnet. If so, I'd have to think it's coming from the tank and/or any possible old steel fuel line into the pump.
#24 | |
![]() Quote:
the car was most likely a show car and is still in excellent cosmetic condition, but was probably shown (i'm guessing here) in one of the classes that emphasize originality and where the cars enjoy little run time. anyway, i don't think any part of the fuel line, from the outlet of the tank to the inlet of the carb, is made of steel except, perhaps, the screen inside the fuel pump. it looks like the majority of it is some kind of copper alloy and a bit of 1/4" hose. BTW, here's a nice one at a more reasonable price...too bad it's has male-to-male connectors. ![]() https://www.speedwaymotors.com/Strai...aign=CSEGOOGLE Last edited by hueyhoolihan; 06-16-2025 at 08:23 PM. |
#25 | |
![]() Quote:
Alan |
#26 |
#27 |
Is this alloy tubing acceptable for use as brake lines?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#28 |
Yes
#29 |
Huey, thanks for taking the time to share your findings. Much appreciated.
Out of curiosity, how much stroke did the fuel pump have? I found a 'new' one in my junk the other day that I want to fit to a motor I'm selling, but it only had about 1/4" movement in it - that didn't seem right to me. |
#30 | |
![]() Quote:
#31 | |
![]() Quote:
i think that ford did experiment, as evidenced by the various pump's gasket dimensions, with the length of the push rod and consequently the length of the throw over the years. the one for my 1941 fuel pump was possibly one of the shorter ones. Last edited by hueyhoolihan; 06-27-2025 at 02:07 PM. |
#32 |
#33 |
Huey and Marko, many thanks
#34 |
The stuff that looks like sand is typically what I see in small motor carbs where Ethanol based fuel was drained and winterized or properly additive used.
WTF is YMMV? |
#35 |
#36 |
OMG ! I will take what's behind door number 2
#37 |
I prefer pranstositional spoubledeak.
Alan |
#38 |
Good one Pete !
