Old 06-24-2025, 10:58 AM   #1
Canton_Model_A's
Canton_Model_A's's Avatar
Question Clutch/Pressure Plate R/R
Guys/Gals:
I am going to be replacing the clutch and pressure plate here in the next month or so. I have already gotten all the parts, Including the spring spreader from Snyders.
My question to the group, is how do you attach the spreader to the rear end so I can get the bolts out of the shackles. Oh and I am also replacing those as well. (Both bolts and shackles)
Images/Pictures/Video would be great here. This will be a interesting task.
1929 Model A Tudor - "Darla"
'29 Model A: Old enough to start with a crank, young enough to steal the show!
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 06-24-2025, 11:39 AM   #2
Phil Brown
Phil Brown's Avatar
Default Re: Clutch/Pressure Plate R/R
You stick the flat end of the spreader in the spring where it rolls back on itself and forms the eye for the shackle (between the spring flat and the rolled eye) Pressure from the spreader will hold it there, but they CAN slip and move a bit. Go slow and easy your first time as you crank out the spreader.
Sorry don't have any pictures of one in use but it is pretty easy once you get started
Phil Brown is offline   Reply With Quote
Old 06-24-2025, 11:54 AM   #3
Mulletwagon
Mulletwagon's Avatar
This should help.
https://www.youtube.com/watch?v=VwT3lhhOWm0
Also plan on changimg all the bushings which will require a reamer after the bushings are pressed in. Let us know how it goes. Good Luck.
Mulletwagon is offline   Reply With Quote
Old 06-24-2025, 12:29 PM   #4
Marshall V. Daut
Some guys like to detach the spring while it is still in the rear crossmember and then drop the rear end assembly. Others drop the whole unit and then remove the spring. I prefer the second method. Both have their advantages and disadvantages, both can be dangerous if certain safety precautions are not observed.
If you drop the whole unit with the rear spring still attached, be sure to immediately affix a large C-Clamp over the center of the spring once it clears the cross member to prevent the upper spring leaves from flying apart if the center bolt is broken or weak from rust. The bottom leaves that are under more compression and tension will stay together if the two spring clamps are left in place. Since you are not going to separate the leaves, keep the spreader and C-Clamp in place while you change clutches. That way, everything should go right back together smoothly. The ends of the spring will still be the correct distance apart in order to insert the spring hangers (shackles).
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 06-24-2025, 01:53 PM   #5
Canton_Model_A's
I don't plan on removing the leaf spring out of the car. so I would just leave the spreader in place while I redo the shackles. and then reassemble.
Motor City A's Club
Old 06-24-2025, 03:56 PM   #6
Marshall V. Daut
Quite correct, it is not necessary to take the spring off the rear axle to change clutches. However, this is the best time to disassemble the rear spring and repair the leaf ends by grinding out depressions caused by the leaves above digging into the ones below, as well as grinding the three corners on each leaf bottom at a 45 degree angle to prevent future gouging. With the spring apart and the leaves repaired in this manner, you can then apply a graphite lubricant (like Slip-Plate) to the bottoms of each leaf (except the bottom main leaf). Chances are that the leaves in your spring are rusted together from lack of lubrication, unless the spring was properly restored in the last few years or someone went to the trouble of spreading the leaves and forcing lube in between them, not an easy thing to do. Then the spring no longer acts like a spring because the leaves are rusted together into one big chunk of steel and have lost the designed-in springing action where the leaves slide across each other. A rusted, dry rear spring will affect the ride and handling characteristics.
Your call, but I think this is the perfect opportunity to address this often- overlooked area in the Model A. You'll also eliminate some of those pesky squeaking noises when you hit a bump in the road. Most of those are caused by dried-out front and rear springs, as well as dried out shackles in need of grease.
Marshall
Old 06-24-2025, 05:51 PM   #7
Tom Endy
Tom Endy's Avatar
This is the safe way to go about it. collapse the spring spreader before attempting to drive the shackle bushings out as you could easily launch the spreader.
http://www.santaanitaas.org/wp-conte...ear-spring.pdf
Tom Endy
Old 06-24-2025, 07:55 PM   #8
Marshall V. Daut
This is how repaired rear spring leaves will look with the gouges in the topsides ground down and the bottom edges beveled on the three sides. Afterwards I used a finer grit disk on the spring leaf tops and smoothed out the coarse grinding disk swirl marks. The tops were painted semi-gloss black and the bottom sides were coated with a graphite lube, such as EZ Slide or Slip Plate.
Yup - A lot of work to repair a Model A spring. But to have a healthy, lively rear spring instead of a solid chunk of stacked, dead metal, it's worth the effort.
And you thought you were only going to change clutches!
Marshall
Old 06-25-2025, 09:56 AM   #9
Canton_Model_A's
I had not planned on re-working the spring this year. it was just to do the Clutch/Pressure plate. Maybe in 2026 I will re-work the leaf spring and take care of it.
Motor City A's Club
Old 06-25-2025, 11:21 AM   #10
JayJay
Marshall
This is more or less how I did both the front and back springs on my '30 TS resto project, but aftger polishing smooth I painted top and bottom of the leaves with the graphite paint. Dang, was that stuff messy!
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 06-25-2025, 12:09 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
I use slip plate on my exhaust manifold. Makes a nice finish and protects from rusting. Use sparingly. I use the spray on a chip brush.
Old 06-25-2025, 01:29 PM   #12
Canton_Model_A's
Another crazy question. When I take off the torque tube from the rear of the transmission, what gaskets will I need to replace. My preferred vendor is Snyders.
The 'Bible' states "Place Gaskets and inner cover over the U-Joint".......
Motor City A's Club
Old 06-25-2025, 02:25 PM   #13
Y-Blockhead
U-Joint gasket set from Snyder's https://www.snydersantiqueauto.com/p...8993&cat=41756
Old 06-26-2025, 07:08 AM   #14
Canton_Model_A's
Thank you Y-Blockhead. I have the set on order, will be here tomorrow. Also ordered another bottle of 600W oil to add to the collection
Motor City A's Club
Old 06-26-2025, 11:52 AM   #15
Mulletwagon
Be sure and check your U-Joint. Now would be the time to change it if there is any significant wear. Finding a good replacement can be challenging.
