Old 06-24-2025, 05:20 PM   #5
nkaminar
nkaminar's Avatar
Default Re: Rubber Casting repro parts.
Traditional rubber needs to be cured at high temperature but there are rubber like compounds that cure at room temperature. Silicone gasket sealant is one. Polyurethane is another. There are many other polymers.
I have cast polyurethane for a machine that I was designing. First I made the plug that is the male part used to make the mold. Then I cast silicone to make a mold. Then I cast the polyurethane into the mold. I made a few parts. The material that I used does not shrink so the plug can be the final size and shape.
The mixed components used for the mold and for the part have to placed in a vacuum chamber to de-air them.
It takes a while for the polyurethane to set but that maybe could be sped up with some moderate heat.
