This is just my opinion but you are probably better off maintaining the existing setup. This has been discussed many times here. The ford pedal has a limited amount of stroke due to the through the floor design. Modern cars with swinging pedals have a lot of extra stroke available as the pedal swings under the dash. (some may differ). The chances are that a dual master cylinder, if one side fails, would need more stroke lower down than the early Ford pedal can supply.
#2 | |
![]() Quote:
I then changed to a 1-1/16" bore E-250 that @Mart mentioned in an earlier thread. This set-up had adequate pedal left when "tested" in the same manner. Also changed out the 1" bore cylinder in my '47 for another E-250 master based on this experience. Probably never have a problem with the smaller bore master when the brake system is maintained in good condition; but if something happened you might not be as safe as you think. Being from the land of rusted out brake lines; I have ended up with very little or no brakes when one lets go a couple times. Guess I just want to be sure on my old cars. |
#3 | |
![]() Quote:
To you guys who are contemplating compromising the original design of your brake system in order to gain what can be of questionable benefit such as a dual master, I would recommend that you reconsider. Your labor will be better spent on maintaining your current system properly than messing up the "geometry" of a factory-designed successful system. When was the last time you flushed your system and replaced the fluid? I have an electronic device that will tell me the moisture content of the fluid. I check every spring before I take my cars out and any one that is even close to the moisture limit gets a fluid flush and change that summer. Along with the fluid check, I perform a visual appraisal of the entire system. EDIT : It's not that the testers are hard to find or expensive : https://www.amazon.com/s?k=brake+flu...tr-ranker_1_20 Last edited by tubman; 06-23-2025 at 03:40 PM. |
