Old 06-22-2025, 10:22 AM   #1
32Bee
Default 35 Horn Wire Hole
There's a 5/8" diameter horn wire hole in each 35 front fender. Would it have
come from the factory with a protective rubber grommet in these holes that
the harness went through?
32Bee is online now   Reply With Quote
Old 06-22-2025, 11:36 AM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 35 Horn Wire Hole
Sorry, I was wrong
Old 06-22-2025, 02:28 PM   #3
32Bee
Thanks Kobe.
Peter
Old 06-22-2025, 02:44 PM   #4
Brian
Brian's Avatar
No, the horns are affixed to the fender with like a coach bolt which has a hole through the center of it, which the wires run through
Old 06-22-2025, 03:12 PM   #5
nelsb01
nelsb01's Avatar
Yup....Brian's got it correct.
The horn bracket which the horn body attaches to is the bolt that attaches the headlight mount to the fender.
You should only have a single horn on your 1935 pickup.
nelsb01 is offline   Reply With Quote
Old 06-22-2025, 05:28 PM   #6
petehoovie
petehoovie's Avatar
You should only have a single horn on you 1935 pickup.
Where did the OP mention a pickup?
Old 06-22-2025, 05:33 PM   #7
nelsb01
nelsb01's Avatar
Now, that is a good question............can I blame the extreme heat on that?
Old 06-23-2025, 06:10 AM   #8
Terry,OH
Terry,OH's Avatar
There is a tar covered cloth loom that the wiring passes through going to the bolt with a hole and from the bolt to the inside the horn cover.
