I have. It doesn't change a thing, it boils in the carb and not the line. The fuel line is only affected because the metal to metal connection at the carb transfers the heat to the line, and a rubber line doesn't affect that.
So where is specifically seems to boil is between the needle valve and the gas line?
With the needle closed, pressure would build to not let gas flow, but when the fuel is sucked up the venturi, the needle would open, relieving the pressure? Or does the boiling gas create bubbles that lift the float not allowing it to open? Isn't the bowl vented to atmosphere? |
