Old 06-19-2025, 01:58 PM   #1
petehoovie
petehoovie's Avatar
Default Re: Wiring: 1933 Ford conduit tube.
Originally Posted by fourfords View Post
I'll try and explain my question. A friend was helping do some wiring on the left side of my stock '33 Ford engine compartment. He left before finishing the task. The conduit tube has the spark plug wires that enter from the front. There are two wires that look like they enter from the back of the tube. one going to the generator, the other to the coil. Do they both go into the tube from the back? or just one? if so, which one?
Thank you.
Old 06-19-2025, 02:54 PM   #2
Zeke3
Zeke3's Avatar
I have a 1937 and I think the left side tube is shorter on the later model and the last spark plug wire also comes out the end. Right or wrong, I installed both the generator wire and the power wire to the coil in the end and out the hole that on the inside left tube, like yours appears to be. Let’s see what the experts say.
Zeke3 is offline   Reply With Quote
