Old 06-08-2025, 07:52 PM   #10
paul2748
paul2748's Avatar
Default Re: Leaking head gasket
Embossed metal head gaskets - are these also called steel shim head gaskets. Even though both surfaces were machined, you may have better luck with the thicker gaskets, which the aforementioned Ted Eaton suggests. And the ones from Best Gaskets which he also suggests..
48 Ford Conv
56 Tbird
54 Ford Victoria
