Old 06-05-2025, 08:36 PM   #1
sandbug
Default Model A Issue - Odd Acceleration or Gear Climb?
A new issue arose. On slight acceleration or slow cruising, the car lurches forward as it's getting a lot of gas, and then it jumps back down (over and over).
I was in a transmission seminar, and took of the tower afterwards to see how my gears are. If I didn't align right when I put back on the tower, could the transmission do this?
Other ideas?
1930 Ford Model A Deluxe Roadster. 1932 B engine, Weber Carburetor (new fuel pump), high compression head, FSI ignition, 12 volts, headers and smitty exhaust.
https://youtu.be/CSwvffB0u1Y?feature=shared
Thanks,
Eric
sandbug is offline   Reply With Quote
Old 06-05-2025, 09:19 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Model A Issue - Odd Acceleration or Gear Climb?
If the transmission shifts the gears normally it can be assumed the tower was reinstalled correctly.
If you have a stock distributor put that back in and see if the problem changes.
Kurt in NJ is online now   Reply With Quote
Old 06-05-2025, 09:31 PM   #3
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I’m betting it’s in the Webber carb.
Old 06-06-2025, 05:04 AM   #4
nkaminar
nkaminar's Avatar
It is not the transmission. Try a stock distributor first.
Also try jetting the carburetor. I had to experiment with different jets to get my Weber to work well. I ended up with larger main jets in both barrels.
But I am going to bet it is in the distributor.
nkaminar is online now   Reply With Quote
Old 06-06-2025, 07:36 AM   #5
Benson
This car
Old 06-06-2025, 07:58 AM   #6
Big hammer
I once tried driving my A without a foot rest, the one next to the accelerator pedal, and it bucked like a wild horse being ridden for the first time.
get a bigger hammer tap done
Old 06-06-2025, 08:58 AM   #7
History
History's Avatar
Imagine what it was like on the roads of the time of the model A , rodeo!
History is offline   Reply With Quote
Old 06-06-2025, 09:05 AM   #8
Richard Knight
Your problem is ignition and or carburetion. If you continue to drive it like that you may end up with transmission troubles. Those may be bolt on mods but to expect the engine to run properly without some tuning by an experienced mechanic would be a miracle.
Richard Knight is offline   Reply With Quote
Old 06-06-2025, 07:57 PM   #9
sandbug
The carburetor has leaked, and stained pieces around it. After I took the filter off, I can see lots of dirt and dust. I took the carb off, and I'm going to rebuild it and clean it up. Thanks and I think this is the issue.
