Permitex makes gasket sealers that are designed for easy disassembly and cleanup, see promotional video at: https://youtu.be/Bd7YV6QHVaU.
Modern engines use gasket sealers that are applied using a robot. The amount and location is controlled precisely. No gasket is used, just the sealer.
