Old 05-19-2025, 08:25 AM   #1
[email protected]
Default Mitchell Overdrive
What is the procedure to remove the driveshaft and pinion from the rear end?
gedoane@bellsouth.net is offline   Reply With Quote
Old 05-19-2025, 08:51 AM   #2
katy
katy's Avatar
Default Re: Mitchell Overdrive
It's in the book!
Old 05-19-2025, 10:15 AM   #3
wuga
The easiest way is using Mitchell's driveshaft/pinion puller. Used it on the last two jobs, it works perfectly and no rear end disassembly.
https://mitchelloverdrives.com/mitch...on-puller-kit/
wuga is offline   Reply With Quote
Old 05-19-2025, 10:32 AM   #4
GPierce
GPierce's Avatar
The instructions that come with the overdrive explain the process. It’s not difficult if you use Mitchell’s tool.
Follow his instructions an do not tighten the drive shaft bolts at the pinion until you have the radius rods connected to the front of the drives shaft.
GPierce is offline   Reply With Quote
Old 05-19-2025, 11:01 AM   #5
Ruth
Like others said, use the Mitchell Pinion removal tool. Steve used to loan them out but I don't know if he does that anymore.
Intructions;
https://www.snydersantiqueauto.com/c...val%20Tool.pdf
Ruth
Old 05-19-2025, 11:18 AM   #6
Tom Endy
Tom Endy's Avatar
http://www.santaanitaas.org/wp-conte...r-Apr-2012.pdf
Tom Endy
Old 05-19-2025, 05:14 PM   #7
Bruce of MN
Bruce of MN's Avatar
Tom's article was my bible in 2020 when I installed mine.
Old 05-22-2025, 07:43 AM   #8
P.S.
If you prefer a more modern way to learn something new . . . Fast forward to about 10 minutes into this video- https://www.youtube.com/watch?v=fKRHYlwR7eU
2024-2025 MAFCA Technical Director
P.S. is offline   Reply With Quote
