Old 05-12-2025, 01:13 PM   #1
s.e.charles
s.e.charles's Avatar
Default 1940 Ford Sway bar to axle connection - photo wanted
i've been able to collect a few sway bar & fittings photos, but lacking a way the sway bar swivel mounts to the front axle.
any direction to search will be helpful; thanks
oops; edit: https://www.jalopyjournal.com/forum/...wivel.1213908/
it's the threaded part on the lower left i don't understand "how"
s.e.charles is offline   Reply With Quote
Old 05-12-2025, 02:01 PM   #2
alchemy
alchemy's Avatar
Default Re: 1940 Ford Sway bar to axle connection - photo wanted
That’s the axle perch. Pre-1935 they held the spring shackle, but 35 and later they only attach the shock link, and sway bar beginning in 40.
alchemy is offline   Reply With Quote
Old 05-12-2025, 07:25 PM   #3
s.e.charles
i think that's why i need a picture . . . .
Old 05-12-2025, 07:33 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
Here’s a drawing of it.
Old 05-12-2025, 08:31 PM   #5
19Fordy
19Fordy's Avatar
Here's the sway bar on my 40.
Old 05-12-2025, 08:37 PM   #6
s.e.charles
i'm really not trying to be a dick, but some stuff i just don't get!
with the picture and some searching i might be able to put the whole assembly into perspective.
just spent hours taking my online "old peoples safe driving course" and i'm sort of frazzled so it's going to be an undertaking for tomorrow.
thanks alchemy & Ken; your patience + responses are a help and i appreciate them.
Old 05-12-2025, 08:39 PM   #7
s.e.charles
19Fordy - please see my post directly above.
and Thank You - you've saved me a bunch of digging for what i am looking for.
if it's okay, i would like to print them for my files.
appreciate you going to the effort of posting them.
Old 05-14-2025, 09:31 AM   #8
19Fordy
19Fordy's Avatar
Charles: You are welcome. You don't need permission to print the photos. If you need anymore photos send me a PM and I'll post them or PM your email address to me and I'll email you the photos you desire.
Old 05-14-2025, 07:06 PM   #9
s.e.charles
thanks for the 'go-ahead.'
i would like to keep further inquiries in this thread if that's okay. maybe others could benefit from the Collective's knowledge.
from current links in other threads, i find myself reading posts from 2008 0r '10 with regularity. it's all new if you don't know it.
Q: is the first picture you posted (front axle parts diagram) from "the Green Book?"
i've been tempted to purchase it online ( around $40) but i've heard it said the information is not entirely accurate.
as of today, tomorrow's wind direction or star alignment may change the plan, i am tempted to buy a series of the Vern Tardel individual components books. saw an ad for a whole bundle for around 125$. forgot how many of which, but it represented a great savings over getting the individual books separately.
i think it was a parts supplier and saved the link in such a secure location i can't put my cursor on it at the moment.
thanks,
sid
Old 05-14-2025, 09:01 PM   #10
19Fordy
19Fordy's Avatar
charles: That photos id from this book: https://www.ebay.com/itm/16141771181...e8ddcef07f6265 I paid $15 for my copy about 40 years ago so look for a better price.
Buy the BIG GREEN BOOK. It's worth the money because there are so many parts that interchange. I have found the info. to be very accurate. Then, if I have a question, I post it on Fordbarn and folks help out.
Goggle: 1940 Ford books and more good books appear:
Old 05-16-2025, 07:47 PM   #11
s.e.charles
okay; i feel better going into this investment with the endorsement.
i have printed the photos you added and am pen outlining the individual components to help me see what's going where. when i estimated for a residential construction company, i used to do this with blueprints ( whiteprints) & prismacolor markers. i helped me discern from often incomplete plans what it was i was looking at.
there will be questions coming. but i really like the caps over the zerk fittings. i just replaced the fittings & greased the hinges on a double leaf 12' high wrought iron gate next to the atlantic ocean and felt luck u could visegrip out what stubs were left after 20 years of exposure so salt air.
and , yes, i did add caps when the job was done!
thanks again,
sid
Old 05-18-2025, 05:29 AM   #12
s.e.charles
i'm getting closer to understanding the mix of things going on:
https://youtu.be/MsCIG-12T68?si=UiSiRS4TLWJrPusY&t=355
Old 05-18-2025, 09:10 AM   #13
19Fordy
19Fordy's Avatar
s.e: Good video. Just take plenty of photos and think the process thru before you start taking things apart. Use penetrating oil to help loosen tie rod ends and bolts. I installed a 4 inch dropped axle, dropped steering arms Posie reversed eye spring in my 40 and it all fit.
Installed 15 in. rims as I wanted the "raked look". I ran the dual exhaust through the frame rails, not under the frame or wishbone. Measure the ID of your brake drums to see if they are within spec. for safety. 12.060 in. max.
ALSO: In the video, it appears that the little canvas spring pad was not installed on top of the spring. BE SURE to install the little canvas pad between the top of the spring and the cross member where the spring center bolt is located to prevent squeaking and wear. I used a thin piece of aluminum so it wouldn't rust OR ABSORB WATER. I tightened spring U-bolt nuts to 80 foot pounds. You can use this pad that already has the center hole in it. Cut length to fit your car. OR you can make your own pad.
https://www.ebay.com/itm/12654871817...5d99a4c4075726
Old 07-08-2025, 12:18 PM   #14
s.e.charles
i've finally had some time to go over the references i was provided in this thread and wanted to say "thank you" to everyone again.
all this 'book-learnin' is helping me understand.
sid
Old 07-08-2025, 10:40 PM   #15
deuce_roadster
deuce_roadster's Avatar
I didn't see anyone mention this but there was an early version of the sway bar that is very different from the one pictured by Ken Alabama. Some of the early chassis books have pictures of that odd one which could be confusing. I have never seen one of the early ones on a car, but they did exist. Kube may have had one on an early restoration.
Old 07-09-2025, 03:31 AM   #16
s.e.charles
i try to, either in the first post, or in some cases the thread title, make it known that the information sought is for scale modeling. i certainly am not constructing museum pieces, but neither do i want something completely divorced from mechanical plausibility.
and i also want to keep the models within a time frame, so while a year or two discrepancy is not too much of a bend, there shouldn't be something jarringly out of place that it calls attention.
thanks for bringing that to my attention. the picture shown is also on the Van Pelt site, which was recommended, and from memory there were at least 2 different ones shown. i did invest in the Green Book, and a lot of what i can use from it is also on the VP pages.
the exploded views of things are helpful, too, but i do need to establish a stopping point in order to actually get something constructed. at 1:24 - 25 scales, the innards of an oil pump system or transmission are of limited value other than personal knowledge.
thanks again & best regards,
sid
