Old 05-07-2025, 12:45 PM   #1
spdway1
spdway1's Avatar
Default Rotor Hitting Distributor Body Contacts
My AA started skipping, popping, and running rough. When I took the distributor body off there was a lot of brass shavings from the rotor hitting TWO of the contacts. What would cause this all of a sudden? Thank you.
spdway1 is offline   Reply With Quote
Old 05-07-2025, 01:06 PM   #2
ndnchf
ndnchf's Avatar
Default Re: Rotor Hitting Distributor Body Contacts
Worn out distributor bushings.
ndnchf is offline   Reply With Quote
Old 05-07-2025, 01:50 PM   #3
JayJay
Or a cracked rotor around where it fits over the distributor shaft…
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 05-07-2025, 04:50 PM   #4
nkaminar
nkaminar's Avatar
A couple years ago I found that the plastic housing (distributor body) I had put on the distributor did not fit tightly and the gap was different depending on which way I pushed on the housing. I found a housing in my collection that fit tightly and that gave uniform gap on all contacts. (I am not sure if contacts is the correct name as the rotor is not normally contacting them.)
After that I set the gap by bending the brass part on the rotor until I had a very small gap. The specification is for 0.025 gap but I found that my car would run a little better with a smaller gap. I ended up with about 0.010 gap. That will only work if there is no slop in any of the parts: rotor, housing, or distributor shaft.
I suggest examining all of the parts, looking for a cracked rotor, as Jay Jay said, or worn bearing in the distributor, as ndnchf said, or a loose housing.
nkaminar is online now   Reply With Quote
Old 05-07-2025, 09:42 PM   #5
Bigsnapper43
I don't use the new Dist.body!!! I have found too many that are not round. I suppose his unit got hot and warped. I just clean up an old unit. 99.9 work fine. The problem area is where the spark advance rod passes close to the 3ed plug wire. Start the car after dark and look for a short. The old unit works just fine...
Bigsnapper43 is offline   Reply With Quote
Old 05-08-2025, 01:11 PM   #6
jw hash
jw hash's Avatar
Big, is right on. I have seen some that are egg shaped. set your timing, loosen up your dist, cam. put your rotor on and turn the rotor and check the gap at each contact. they should be all close to the same. I don`t remember what that gap should be. maybe someone can put that Number on here.
jw hash is offline   Reply With Quote
Old 05-08-2025, 01:37 PM   #7
JayJay
The standard spec is 0.025”. But frankly, a bit closer won’t hurt at all. You need to reset timing after fiddling with the gap.
JayJay
Old 05-11-2025, 06:43 PM   #8
spdway1
spdway1's Avatar
UPDATE: The distributor shaft has NO play (side to side). With another new cap and rotor from Snyders, Position (cylinders) 3 & 1 have a proper clearance of .025. Position (cylinders) 2 & 4, the rotor hits the contacts on the distributor body. I have tested this by turning the engine over with a crank. What can I do to fix this with what I have on hand?
Old 05-11-2025, 06:55 PM   #9
Gold Digger
If I was going to use that cap I would file the tips inside the cap on the one's that were too close. Or otherwise find another cap.
Gold Digger is online now   Reply With Quote
Old 05-12-2025, 05:42 AM   #10
nkaminar
nkaminar's Avatar
Gold Digger has a good suggestion. But make sure that the cap fits the distributor snugly before doing any filing. If it is loose, get another cap.
Old 05-12-2025, 06:46 AM   #11
Fullraceflathead
Fullraceflathead's Avatar
I have worked in quality control with injection molded plastic for many years I've got a sneaky suspicion that they're running these caps and distributor housings at too fast of a cycle on the injection molding machine and they're coming out too hot and a little bit soft like putty and they are warping oval as they cool. I'll bet, if you measure across the pins with a pair of calipers you're gonna see that the housing is oval. The old original caps and housings were made from Bakelite and that's a whole different piece but the modern material is not the same as the old Bakelite!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 05-12-2025, 07:12 AM   #12
CT Jack
CT Jack's Avatar
Many good tips posted. I prefer to mount the distributor in a vise with the points, rotor and cam removed and indicate the runout of the shaft. This will identify if the bushings are worn and in need of replacement. Runout should be > .005". This is the most important 1st step. Too much runout will cause a variation in point gap and can also cause the rotor to make contact with the contact pickups on the inside of the cap. There are many cap manufacturers and some have produced caps with variations in the height of the contact pickups. Measuring the gap between the rotor and the pickups should be uniform as noted in post#8.
CT Jack is offline   Reply With Quote
Old 05-12-2025, 07:46 AM   #13
Big hammer
Please let Synder’s know of your issue ! File or grind clearance on # 2 & 4 contacts
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 05-12-2025, 08:34 AM   #14
Y-Blockhead
Y-Blockhead's Avatar
Not to mention varying the timing as the point gap changes.
Old 05-12-2025, 08:49 AM   #15
katy
katy's Avatar
Ditto
Old 05-12-2025, 08:56 AM   #16
nkaminar
nkaminar's Avatar
CJ Jack, I think you meant to say that the runout should be < 0.005 not >. (Less than not greater than.) 0.005 seems a little too much to me. I would shoot for 0.001 or less.
Old 05-12-2025, 07:31 PM   #17
CT Jack
CT Jack's Avatar
Neal, yes my error. It should be <.
