Old 04-27-2025, 06:24 AM   #1
Ed Saniewski
Ed Saniewski's Avatar
Default resistor under dash 1933
There is a open coil resistor under the dash that is rusted and broken. The former owner has a jumper across the two ends. What is this for ? I found a wiring diagram that leads me to think it is for the ignition coil. Thanks
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
https://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 04-27-2025, 06:52 AM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: resistor under dash 1933
Resistor limits current to points. So extends life of points & coil.
Old 04-27-2025, 08:18 AM   #3
Bored&Stroked
Bored&Stroked's Avatar
It is for the coil - you'll definitely want one (or a suitable replacement) as it prevents over-voltage to the coil and burning your points.
Old 04-28-2025, 06:55 AM   #4
Terry,OH
Terry,OH's Avatar
The resistor should have a cage around it and should measure 0.5 to 0.6 Ohm. Sounds as if the PO was running a different coil than the Ford. If so the resistor value may change from Fords.
Old 04-28-2025, 07:01 AM   #5
Mac VP
Mac VP's Avatar
The original resistor was designed to work with the original type Ford coil (which was mounted atop the Ford distributor). If the previous owner bypassed this resistor he may have changed to a remote mounted 6V coil, which would handle the full 6 volt input no problem. If the vehicle is again running with an original coil, you should replace the old damaged one with a new one. Part number is 18-12250. We and a few other vendors stock a high quality USA made part.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 04-30-2025, 09:34 PM   #6
mcgarrett
From what I've read about this, the resistor is especially important to keep from burning the points by reducing the voltage going to them to 4 volts.
Old 05-01-2025, 05:12 AM   #7
Ed Saniewski
Thanks to all, I ordered one from third gen parts. The P O had jumped the resistor and caused the coil to overheat and explode.
