Old 04-27-2025, 02:17 AM   #1
acchaplin
Default Re: '32 Roadster top color
Originally Posted by rockfla View Post
Acchaplin
Hopefully you will share the source and color numbers you find with Us here on the barn, I for one would love to order several yards.
SURE WILL!
I found a subistute tan rubber mat. 5'X10' .055 thick, for the same price Bob Drake wanted for his re-popp front mat! I covered the entire floor with it! It's a shade lighter than Drakes' mat.
Took a while. Did it in two sections. Front part is from the firewall insulation pad back to and around the seat riser. The back rear part is from inside the seat riser back to panel under the trunk latch. I moved my seat riser and renforcement plate back 4-5 inches. (more leg room)Took a bunch of cereal box, pop and beer carton cardboard. Carefully cut the cardboard out to fit the contour for each floor section. Then taped all those cardboard pieces together to make one big pattern. Laid that pattern out of the rubber mat, traced around it and marked out all the holes with a sharpie. Then cut the mat to just the inside of the sharpie line. Perfect fit!
I had posted the floor companies name on here. I don't think it generated much interest
This rubber mat is for trailer and garage flooring cover. Elete Floor Coverings.
acchaplin is offline   Reply With Quote
