After exhaustively searching the internet for the original paint color on the early G-Series 6-Cylinder engines, I took some paint thinner and wiped away what I can only assume was a topcoat of rattlecan regular Ford Engine Green paint, to reveal the remnants original paint!
I had it color matched in PPG Deltron and figured I would share the information in the hope that it helps someone else with a G-Series 6 Cylinder who is striving for an original look. In real life, the paint is a super close match, even better than it shows up in the photo because of lighting. I will follow up with the formula |
So, you matched a sampling of 75+ year old paint?
Kube,
Point well taken. If you know of a definitive color sample available somewhere, I sure couldn’t find it,, and would love to see it. Even though this original paint has been heat cycled a million times, at least it hasn’t been fading out in the sun for years like paint on a car roof, and to my way of thinking it has to be infinitely better than going off a rough description like “a light off-shade of Ford Engine Green”. Maybe it can serve as a starting point for someone. Or maybe not…. |
#5 | |
I commend you on your diligence. Not too many guys would have bothered. When I was painting cars, it was always quite a project to match the authentic colors. Probably easier than engine paint I'm guessing.
