#21 |
I guess I'll have to ask; this IS a run stand isn't it?
#22 |
Yes/no. Using my speedster chassis as the test stand.
#23 |
That explains the brass cooling plumbing.
#24 |
Yeah, got a rear mounted rad. Just wrapped up the coolant system. Got some leaks at the pump gaskets. If interested, here’s the link to my build thread on the HAMB.
https://www.jalopyjournal.com/forum/...131795/page-32 |
#25 |
For what it is worth I tried those fuel fittings with the built in ferrule. I didn't like them. I did find, though, that the nuts will still work with a conventional barrel shaped ferrule. Nuts designed for use with separate ferrules are preferable but the other nuts will work in a pinch.
Mart. |
#26 |
#27 | |
![]() Quote:
Al Hook |
#28 |
Amen!
#29 |
good thing you wondered, inquired and got it all sorted out. fuel leaks don't cut it! and I never seen a loose fuel line fitting/connection that did not leak!
"My Model A... work never ends, only the day ends!" |
