Old 04-09-2025, 12:12 PM   #1
Rockymountainsparky
Default Hinge pin removal
I'm trying to remove the hinge pins on my 36 coupe so that I can install a pair of hinge mirrors. The pin removal tool that I bought keeps drifting so that it is half off the hinge pin. no matter how many times I've tried, it keep moving.
I've tried using a punch and hammer. But it doesn't budge.
Any suggestions?
Rockymountainsparky is offline   Reply With Quote
Old 04-09-2025, 12:24 PM   #2
Woodie1
Woodie1's Avatar
Default Re: Hinge pin removal
Removing hinge pins is a pain. I had to heat mine to get them out but the car wasn't painted at the time. Maybe you could go with a coupe of door edge mounts.
Woodie1 is offline   Reply With Quote
Old 04-09-2025, 01:02 PM   #3
ActionYobbo
ActionYobbo's Avatar
https://m.youtube.com/watch?v=Jw7Ear2cy7U
Here is a video. Using the method in the video there is no need to crank a lot of pressure on the pin with the tool. Also you can use a corner of 80 grit paper between the tool and the pin to give it a bit of grip to get started.
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 04-09-2025, 01:55 PM   #4
Zeke3
Zeke3's Avatar
That is a great video! I have also used the hinge pin tool to remove stuck clevis pins that you can’t access with a hammer, like on 1937 cable brakes.
Zeke3 is offline   Reply With Quote
Old 04-09-2025, 02:45 PM   #5
Rockymountainsparky
Boy, I wish that it was as easy as in that video. I'll give that sandpaper a try. Thanks!
Old 04-09-2025, 03:53 PM   #6
ActionYobbo
Another tip is don’t have the door latched. That can put lateral pressure on the hinges if the door is hard to close. Try and find a neutral weight/pressure position with the door.
Old 04-09-2025, 05:37 PM   #7
wickcopland
wickcopland's Avatar
I removed mine using some heat and my air hammer. They came out fairly easily.
wickcopland is online now   Reply With Quote
Old 04-09-2025, 06:54 PM   #8
Newc
Newc's Avatar
Normal pins are only swedged the top 1/4" or 3/8th". I drill out that bit. Newc
Old 04-10-2025, 11:44 AM   #9
Rockymountainsparky
Well, I'll be dammed! The sandpaper worked. Thank you so much.
Old 04-10-2025, 01:11 PM   #10
ActionYobbo
My pleasure. Glad you got it with out messing up the paint. Did it come out as easy as the pins in the video?
Old 04-10-2025, 03:12 PM   #11
petehoovie
petehoovie's Avatar
Old 04-11-2025, 01:28 PM   #12
Rockymountainsparky
The passenger side... yes. Driver side was a real bear.
