Old 03-29-2025, 09:31 PM   #10
hotrodA
hotrodA's Avatar
Default Re: Camber adj. on '40 chassis with 4" dropped axle
Worn kingpins will let the tires toe out resulting in inner tread wear, letting the tire scuff in to out. You can set the toe, but still have the negative camber setting from the worn pins.
Post a pic of the axle mods.
hotrodA is offline   Reply With Quote
