Old 02-28-2025, 10:31 AM   #1
Tom F OHIO
Tom F OHIO's Avatar
Default Fan Blade
We put a new fan blade on the car and the tip of the blade is just barely hitting the upper hose to the radiator. Is there a fix for this. Thanks....
Tom F OHIO is offline   Reply With Quote
Old 02-28-2025, 11:01 AM   #2
Joe K
Joe K's Avatar
Default Re: Fan Blade
Check the "quality" of the new blade. Compare it dimensionally to the previous blade.
Supposedly new is made to the same dimensions as the old - but overseas being overseas also implies overseas quality control. As in frequently inadequate. Venders are not to blame for this but if you find something egregious in your comparison, they may replace it for you gratus.
Check also that the radiator/pump discharge connector is "matched." Model As exist in two persona - 28-29/lower radiator and 30-31/higher radiator. The casting/connection above the water pump is different between the two personas and you can't mis-match well.
Your radiator is likely NOT an original Ford radiator. More likely someone's "idea" of what constitutes a Ford Model A radiator. Angles/positions of the connections may be different than the original Ford design as 1950s, 60's, 70's, later producers continued to make a "mostly acceptable" product. One thinks of JC Whitney who produced a "replacement" radiator. Even Sears/Allstate was in this game.
A solution may be found in replacing the upper straight cylindrical radiator hose with a "near straight" hose found at your auto parts dealer.
I myself have a Gordon-Smith Compressor which is obviously "made of parts" including a dual tank/foundation with welded landing pads for the radiator mount - the height of the radiator is "not quite right" even though the 30-31 Radiator is matched to a 30-31 Water Pump discharge neck. I had your interference here and solved it by purchasing and cutting down a later model "bent" hose from Autozone.
Suggestions. Let us know what you find.
Joe K
Shudda kept the horse.
Old 02-28-2025, 11:12 AM   #3
nkaminar
nkaminar's Avatar
Is this a two-bladed fan or a four-bladed fan? I would be inclined to grind away some material on the tips, being careful to grind away an equal amount so to keep it in balance and perhaps check the balance on a shaft on knife blades.
Old 02-28-2025, 11:16 AM   #4
Richard Knight
Sagging frame rails and failed motor mounts can contribute to this issue.
Richard Knight is offline   Reply With Quote
Old 02-28-2025, 05:56 PM   #5
mass A man
mass A man's Avatar
Check the correct height for the front motor mount.
mass A man is offline   Reply With Quote
Old 03-01-2025, 09:38 AM   #6
Tom F OHIO
Tom F OHIO's Avatar
Thanks for ther suggestions. Going over Tuesday to work on the car. Hopefully we
can figure this out.
Old 03-27-2025, 03:39 PM   #7
fastroadster
Do I need to remove radiator to replace my fan?
fastroadster is offline   Reply With Quote
Old 03-27-2025, 04:27 PM   #8
Herb Concord Ca
If a two-blade fan AND bolts not studs holding water pump to head. No, you don't have to remove the radiator, moving the radiator supports rod may also help.
Herb Concord Ca is offline   Reply With Quote
Old 03-27-2025, 05:03 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
Remove the support rods and tilt the radiator forward. I always put a piece of cardboard on the rediator to protect it.
