Old 02-26-2025, 10:27 PM   #2
JayChicago
JayChicago's Avatar
Default Re: Turn Signals
That is a classic symptom of poor ground at the light socket. The voltage from the running lights can't go to ground easily, so interferes with the turn signal voltage trying to get to ground. (and visa-versa) Solution is to clean up the light bulb socket and the socket's connection to ground on the body. Sometimes running a dedicated ground wire to the frame will be the solution.
