Old 02-06-2025, 04:00 PM   #7
expavr
expavr's Avatar
Default Re: 40/41 Truck cab measurements.
Using the same location on the 40 Tonner hinges for checking the cab measurements that Gary used I came up with 40 5/8". Using 40 1/2" as Gary suggests should be a safe X check to get you close.
Photos of cab corners are attached.
expavr is offline   Reply With Quote
