Old 02-03-2025, 02:09 PM   #1
rhpope
Default 9" and 9-1/2" Clutch and Pressure Plate Questions
My questions are about the comparison between the 9" and the 9-1/2" clutches
The 9" clutch is just the typical clutch that was used for many years that used a standard Long style pressure plate. See the link.
https://fortwayneclutch.com/product/...ew-sku-kt5102/
For the 9-1/2" clutch, the pressure plate looks different than a standard Long pressure plate, but it still appears very similar. See the link.
https://fortwayneclutch.com/product/...t8594-1-375_r/
My questions are these:
Will the two interchange on the same flywheel or is there a difference in pressure plate bolt pattern?
What are the bolt circle dimensions on the two different pressure plates?
I have a 9-1/2" pressure plate that I measured the center line of the bolt circle to be approximately 10-7/8". I do not have a 9" pressure plate to measure the bolt circle. Is the 9" approximately 1/2" in diameter smaller?
Is it flywheel specific and would have to be redrilled if changing the size of the clutch and pressure plate between 9" and 9-1/2"?
Thanks for any help,
Roger
rhpope is offline   Reply With Quote
