Old 01-18-2025, 10:18 PM   #1
TomC750
TomC750's Avatar
Default '41 distributor cap
How does one separate the two parts of a 1941 distributor? Looks like the key is the "pin" in the center, but I don't know how to remove it. Need to get the wires removed prior to sending it to Charlie for a tune-up. Tried to send a pic as well, but our lousy internet could not cope with it right now.
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 01-19-2025, 07:45 AM   #2
corvette8n
corvette8n's Avatar
Default Re: '41 distributor cap
I just unbolted my whole distributor from the car and sent it to Charlie. See the pics I found on this website. This one has the remote coil setup.
Old 01-19-2025, 11:54 AM   #3
TomC750
TomC750's Avatar
Corvette8N, OK, looked at the pics, noticed that the plug wires are disconnected from the distributor caps. This is what I am trying to accomplish, but do not know how to get the wires out.
Tried again to attach a pic, it times out. Frustrating - No good internet available here!
TomC750
1930 1 Ton White
Old 01-19-2025, 03:25 PM   #4
Fritz
Fritz's Avatar
Slide the wire bails off and you can pull off the dome caps.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 01-19-2025, 07:59 PM   #5
TomC750
TomC750's Avatar
That is NOT the problem! If I could manage to attach a pic it would be evident that I have the caps off but not the wires out of the caps. This is so frustrating to get across my problem without a pic. I sent a pic of my car to a friend, but for some reason my pic attachment on this site this site is not working. My upload is a pathetic .25 mbps! And that is why it times out.
TomC750
1930 1 Ton White
Old 01-19-2025, 08:17 PM   #6
TomC750
TomC750's Avatar
I think at this point I will snake the wires out of the metal conduits, wrap up the wires with attached caps and send the whole works to Charlie.
TomC750
1930 1 Ton White
Old 01-20-2025, 06:53 AM   #7
Terry,OH
Terry,OH's Avatar
The center post of the outer cap passes through the inner cap. On the inside of the inner cap there is a rubber O-ring holding the two caps together. If the rubber has turned hard cut it off.
Old 01-20-2025, 07:48 AM   #8
38 coupe
38 coupe's Avatar
Sometimes the outer caps stick in the distributor housing. If that happens take the coil off the top and gently tap the caps out using a wooden dowel, a screwdriver handle, or similar. Frequently the easiest disassembly is to get the caps off the distributor, pull at least one side spark plug conduit, then pull the distributor from the engine.
Terry described how to separate the outer cap from the inner cap.
When putting things back together if there is any combination of new inner cap and/or rotor then check for the rotor hitting the caps. About 1/3 of the time I have to file one or more of the brass cap studs for clearance since something hits.
Old 01-20-2025, 09:56 AM   #9
TomC750
TomC750's Avatar
Terry, thank you. I did figure it out this morning. I assumed that the rubber ring was just a seal. I looked in my "Green Bible" to see what the ring was called, a retainer. Ahah! I worried it out with a small pic. The ring is fresh as new. I do have to do the other side but wanted to respond ASAP. Thank you.
I do have to say the Greene Bible is worth its weight in gold!
TomC750
1930 1 Ton White
Old 01-20-2025, 10:03 AM   #10
TomC750
TomC750's Avatar
39 Coupe, The caps literally fell off, no problem there. You and Terry were the first that really understood, but maybe my communication skills were lacking. And thanks for the hint about the rotor clearance. I will take heed. Thank you!
TomC750
1930 1 Ton White
