Old 01-19-2025, 05:52 PM   #11
Tim Ayers
Default Re: Removing Stuck Heads
Originally Posted by Ken/Alabama View Post
I gave up trying to remove the studs. I rung two off and they broke flush with the head and not the block so that tells me the studs are seized to the heads.
Are you trying to save the heads if possible? If not, may be time to use a zip wheel and starting making slices 7/8th the way through. Eventually they will crack apart.
