Old 12-04-2024, 08:33 AM   #1
Admiral Tom
Default 1936 Door locks
I want to install a keyed lock on my 1936 PU's driver side door. Can a passenger door lock assembly be somehow used on the driver's door?
Also, my current driver's outside door handle "droops" instead of staying at a 270 degree position. Is there a spring inside the door lock assembly I can change, or do I need to get a "new" handle? Thanks!
Admiral Tom is offline   Reply With Quote
Old 12-04-2024, 09:10 AM   #2
tubman
tubman's Avatar
Default Re: 1936 Door locks
For "droopy" door handles, start here : https://www.fordbarn.com/forum/showt...ng+door+handle.
Old 12-04-2024, 11:08 AM   #3
Planojc
Planojc's Avatar
Replaced the springs on both latches recently, Springs came from Third Gen.
Planojc is offline   Reply With Quote
Old 12-04-2024, 03:05 PM   #4
deuce lover
deuce lover's Avatar
To answer your first question, No they will not interchange.
To your second question.You need to pull the latch and see what the problem is which is most likely the spring as Tubman has pointed out.
Old 12-04-2024, 03:43 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
A lot of times the square part of the handle wears along with the square hole it fits into.
For my car I searched for NOS Handles and latches — some cost me less than the reproduction springs
To know your problem you have to take it apart
Old 12-04-2024, 06:45 PM   #6
drolston
drolston's Avatar
My droopy door handle is due to worn square shaft and receiver in the latch mechanism. My fix is to always pull the handle up after I use it. There is enough friction that it stays in place, even after driving on a rough road. Could replace the handle with a better one, but the driver side latch mechanisms in like-new non-droopy condition are pretty hard to find.
Old 12-04-2024, 09:17 PM   #7
Zeke3
Zeke3's Avatar
Bob Drake shows a kit for mounting a lock cylinder on the left side of a pickup door, kit number BD-104-K. You also need to purchase a lock cylinder.
I also had a droopy left side door handle on my 1937 pass car. I was able to fix it with a new door latch. I think the old latch could have been fixed with a new return spring, but I didn’t pursue that when I found the new latch.
Zeke3 is offline   Reply With Quote
Old 12-04-2024, 09:55 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
Is it an open car or closed car ?
Old 12-05-2024, 01:13 AM   #9
deuce lover
He states in the first post that it is a 36 pickup.
Old 12-07-2024, 08:51 PM   #10
danliveshere
danliveshere's Avatar
Tom you would need to find a latch from a Rhd vehicle. Our locks are on your driver side!
danliveshere is offline   Reply With Quote
Old 12-07-2024, 08:59 PM   #11
325w
You can take crescent wrench to the square shaft and put a sight twist in it. Levels the handle. Along with a new spring
325w is offline   Reply With Quote
Old 12-08-2024, 09:30 PM   #12
Admiral Tom
Talking Re: 1936 Door locks
Thanks for all the replies! They all are welcomed! Heaven knows I need all the help I can get ! Regarding DANLIVESHERE's response (I'd post him directly, myself, but I don't have enough posts in my que as yet to do so!) does anyone know of any "Down Under" web sites that might have a lead on a Rhd Latch?!
Thanks, again, for all your help!!
Old 12-09-2024, 01:38 PM   #13
swedishsteel
As well as twisting the shaft a little to cure the droop, if the shaft is worn severely you can use a wire feed welder and weld up the worn spot and then grind/file it square again. My fix on more than one.
swedishsteel is offline   Reply With Quote
