Old 11-26-2024, 10:23 AM   #1
Russell Reay
Russell Reay's Avatar
Default Re: T5 vs AX 5 or AX15
A major reason for wanting the modern trans is the synchromesh. I can downshift the A trans, but not at high speed (30-40+). Slowing down from hi-way speed for entry to a driveway (5> 4>3) plus brakes is so much easier with a synchro than the model A ( 3> brakes > brakes> brakes >2).
Russell Reay is offline   Reply With Quote
Old 11-26-2024, 10:49 AM   #2
Y-Blockhead
Y-Blockhead's Avatar
Ah, but you can down shift with the Mitchell O/D. The Mitchell has synchros.
Old 11-26-2024, 01:21 PM   #3
JayJay
Aren’t the synchro rings only on second and third? IIRC first is still crash box.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 11-26-2024, 04:54 PM   #4
Y-Blockhead
Hi, JayJay, I was referring to the Mitchell O/D, not the Mitchell transmission. You are correct, the Mitchell Trans has second and third gear synchros.
But the O/D has high and low range with synchros. Simply put the Mitchell O/D in neutral and you can shift the Model A Trans into any gear you want, then re-engage the Mitchell O/D... within reason. I wouldn't recommend shifting into first at 40mph!!
