Old 11-23-2024, 02:24 PM   #5
Fritz
Fritz's Avatar
Default Re: Chasing same issues again any ideas? ‘34
If you only have 4.5 volts at the powered side of the resistor, you’re losing 2 volts between the battery and the resistor, probably at the ignition switch. Finding out where you are losing that 2 volts will help.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
