Old 11-04-2024, 03:02 AM   #21
Mtn Wudy
Mtn Wudy's Avatar
Default Re: Dash light
I can't get the cover back on good ....
Is there knack to putting it on .?
Mine wants to drop off....
It's a '29..
Whether you think that you can,or that you can't,you are usually right....H.Ford
Mtn Wudy is offline   Reply With Quote
Old 11-04-2024, 09:50 AM   #22
Tom F OHIO
Tom F OHIO's Avatar
Originally Posted by The Master Cylinder View Post
I have never seen a single fiiment bulb with offset pins. I see no use to do that. I am using a LED in my Town Sedan, burned my fingers one to many times using an regular bulb!
I put one in my car also and can actually see the dash now when its dark out.
Tom F OHIO is offline   Reply With Quote
Old 11-04-2024, 07:13 PM   #23
veteran#94
my dashlight is tore apart does anybody know where i can get picture to put it back together.
veteran#94 is offline   Reply With Quote
Old 11-06-2024, 10:19 AM   #24
rotorwrench
rotorwrench's Avatar
The early type base wasn't really made to be taken apart since a little metal bent tab has to be straitened to disassemble. If the tab breaks off then the housing is done. The outer cover was made to be removable for bulb replacement.
Find an old GE miniature bulb catalog and you can get all the numbers for replacements of same design bulbs. Edison Mazda/GE designed all the most common bulbs and continued to manufacture them for years. Each design bulb has a reference code so a person can tell whether it fits or not. They came in various voltages and candle powers
Old 11-06-2024, 10:43 AM   #25
katy
katy's Avatar
One may or may not be able to solder the broken tab back on, I've soldered the broken tabs on the horn button retainer.
katy is online now   Reply With Quote
Old 11-06-2024, 11:07 AM   #26
rotorwrench
I think I'd try finding a way to eliminate the tab first. If it can be disassembled then it would be easier to maintain it.
Old 11-06-2024, 11:08 AM   #27
Canton_Model_A's
Canton_Model_A's's Avatar
on another note within this thread, I need to replace my entire lamp assembly. The normal suppliers state Out of Stock, any source for a replacement?
1929 Model A Tudor - "Darla"
'29 Model A: Old enough to start with a crank, young enough to steal the show!
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is online now   Reply With Quote
Old 11-07-2024, 11:11 AM   #28
rotorwrench
Recently, I was lucky enough to find a repairable used one on flea-pay. I used a reproduction socket pigtail for a 28/29 headlamp to replace the damaged pig tail. The new reproductions have been out of stock for a long time with no guarantee of further replacements.
Old 11-07-2024, 11:27 AM   #29
Cape Codder
Cape Codder's Avatar
Several comments about using an LED Bulb for the Dash Light BUT no one has offered the type or number ! Can someone help ?
I also like attaching it to the ignition switch!
I don't care if the "A" Starts BUT sure WANT IT TO STOP!
Cape Codder is offline   Reply With Quote
Old 11-07-2024, 12:01 PM   #30
Y-Blockhead
Y-Blockhead's Avatar
Cape, sorry, I can't remember that far back. According to my records I installed it in December of 2014.
If I get out to the car today I will check. I don't know if it will help you tho. My car is 12v.
If it helps at all, the dash light takes the same bulb as the cowl and dome lights.
Old 11-07-2024, 12:29 PM   #31
Y-Blockhead
Cape Codder, I believe this is the LED I used in my dash light. https://www.superbrightleds.com/led-...volts-12V~ACDC
I see it comes in 6v but only available in the 32° version. I think it should work fine, they are pretty bright.
I have the 12v, warm white, 90° version in my '30 Town Sedan.
Old 11-07-2024, 05:18 PM   #32
Cape Codder
Y-Blockhead - Thanks for the Info for the LED Bulb! Has to be better than what ORIGINAL gives me.
Old 11-07-2024, 08:05 PM   #33
Harpkatt
Harpkatt's Avatar
I put an amber LED in my coupe, it was perfect, Plenty of light without being too bright and had kind of a natural color. It was a bulb from my cowl lights.
It did burn out and I haven't replaced it though.
6V car.
Harpkatt is offline   Reply With Quote
Old 11-08-2024, 08:40 AM   #34
bobv
bobv's Avatar
https://www.snydersantiqueauto.com/p...7953&cat=41724
bobv is offline   Reply With Quote
Old 11-08-2024, 10:07 AM   #35
rackops
rackops's Avatar
If I wasn't a "purist", I'd add a separate switch for the dash light. Maybe just a small toggle on the bottom of the dash. Has anyone done that before? Seems to be a great fix to alleviate any hot covers and avoids the reliance on the spring to pop in and out.
Member, MARC
Current owner, 1928 RHD Australian-built Phaeton CA4752 "Felicity" and a 1931 Victoria "Katie"
Former owner, 1929 Phaeton, 1929 Fordor
rackops is offline   Reply With Quote
Old 11-09-2024, 02:53 PM   #36
Cape Codder
I really like nkaminar's idea a LOT ! That's not to say I would E V E R forget to turn it OFF !
