Old 10-26-2024, 06:29 AM   #1
mike42
mike42's Avatar
Default 1940 Rear Drum and Hubs
Morning…….
Looking to replace the rear drums on my ‘40 and was wondering if it’s wish to use the old hubs with the new drums. I understand they are pressed into the drums !!
Thx, Mike
mike42 is offline   Reply With Quote
Old 10-26-2024, 09:27 AM   #2
Tim Ayers
Default Re: 1940 Rear Drum and Hubs
Mike,
Depends on which new drums you are talking about. Boling Bros make excellent US-made drums that are designed to SLIP on stock or replacement stock-style hubs. Only change is you need to remove the stock studs and install slightly oversized knurled studs. They sell all the parts you need.
If going this route, then yes you can reuse your stock '40 hubs.
Member Krylon32 AKA Gary @ Cornhuskers in offering members 10% Boling Bros brake parts.
Old 10-26-2024, 11:43 AM   #3
19Fordy
19Fordy's Avatar
Mike: Make your life easy and buy the Boling Bros. hubs and matching drums and grease seals. See photos below. Goes together nice and easy. Contact Gary (Krylon) and you will get all the info. you need from him. Be sure to ask him about reusing your OEM bearings instead of the Boling Bros. bearings as I have heard that the aftermarket bearings are not very good. I used the OEM bearings when I bought my Boling Bros drums and kit from Gary back in 1999. Excellent vendor with an excellent product. Do not discard your OEM bearings.
Old 10-26-2024, 12:34 PM   #4
Fritz
Fritz's Avatar
Last I heard Boling Brothers had a pause on making new hubs. If your original hubs are in good shape, they are the best route. Just drill/knock out your old studs and drums and use modern studs with new slip on drums.
The studs I use are Dorman 610-289. They will install directly into your hubs without enlarging any holes.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 10-26-2024, 02:28 PM   #5
Charlie Stephens
Old hubs will work with new drums but you MUST find someone that knows what they are doing to install them. DO NOT settle for someone that thinks they can do it and has a large hammer. It requires knowledge and a large press. Inquire at local clubs and see who does it.
Charlie Stephens
Old 10-27-2024, 06:05 AM   #6
mike42
mike42's Avatar
Morning Guys…….
This is exactly what I was looking for. My next question was going to be who makes good drums and you answered that before I asked !! I appreciate the responses. ����
Thx, Mike
